Правильно понимаю, в консоль python
в строку где >>>
вставляю
python -m pip install --target "C:\Users\n.starkova\AppData\Roaming\ESTI\Axioma.GIS\v5\installed_modules\dependencies" "C:\tmp\generateDS-2.43.3-py3-none-any.whl" ?
Unhandled Python Exception:
File "C:\Program Files\Axioma v5\bin\python\Lib\code.py", line 63, in runsource
code = self.compile(source, filename, symbol)
File "C:\Program Files\Axioma v5\bin\python\Lib\codeop.py", line 178, in __call__
return _maybe_compile(self.compiler, source, filename, symbol)
File "C:\Program Files\Axioma v5\bin\python\Lib\codeop.py", line 106, in _maybe_compile
raise err1
File "C:\Program Files\Axioma v5\bin\python\Lib\codeop.py", line 93, in _maybe_compile
code1 = compiler(source + "\n", filename, symbol)
File "C:\Program Files\Axioma v5\bin\python\Lib\codeop.py", line 143, in __call__
codeob = compile(source, filename, symbol, self.flags, 1)
File "<console>", line 1
SyntaxError: invalid syntax
в строку где >>>
вставляю
raise err1
нет .
В windows cmd ( у меня Axioma установлена не в C:\Program Files ) в вашем случае . Нужно делать cd "C:\Program Files\Axioma.Gis"
LiSa писал(а): ↑18 апр 2024, 11:26 Правильно понимаю, в консоль python
в строку где >>>
вставляю
raise err1
Спасибо за обратную связь.
В командной строке Windows получили следующее:
c:\Program Files\Axioma v5\bin\python>python -m pip install --target "C:\Users\n.starkova\AppData\Roaming\ESTI\Axioma.GIS\v5\installed_modules\dependencies" "C:\tmp\generateDS-2.43.3-py3-none-any.whl"
C:\Program Files\Axioma v5\bin\python\Lib\site-packages\shiboken2\files.dir\shibokensupport\feature.py:139: DeprecationWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html
Processing c:\tmp\generateds-2.43.3-py3-none-any.whl
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='pypi.org', port=443): Read timed out. (read timeout=15)")': /simple/six/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='pypi.org', port=443): Read timed out. (read timeout=15)")': /simple/six/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='pypi.org', port=443): Read timed out. (read timeout=15)")': /simple/six/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='pypi.org', port=443): Read timed out. (read timeout=15)")': /simple/six/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='pypi.org', port=443): Read timed out. (read timeout=15)")': /simple/six/
INFO: pip is looking at multiple versions of generateds to determine which version is compatible with other requirements. This could take a while.
ERROR: Could not find a version that satisfies the requirement six (from generateds) (from versions: none)
ERROR: No matching distribution found for six
В generateDs ( основном модуле ) много зависимостей.
Попробуйте скачать https://disk.yandex.ru/d/klZuhk1hwxrgFQ и распаковать в папку C:\Users\<имя пользователя> \AppData\Roaming\ESTI\Axioma.GIS\v5\installed_modules\dependencies\
Должно быть вот так
Должно быть вот так
LiSa писал(а): ↑18 апр 2024, 14:46 Спасибо за обратную связь.
Для Windows 64 бит, скачайте Распакуйте архив и запустите setup.batgisamap писал(а): ↑18 апр 2024, 16:42 В generateDs ( основном модуле ) много зависимостей.
Здравствуйте! Скопировала файлы в папку C:\Users\n.starkova\AppData\Roaming\ESTI\Axioma.GIS\v5\installed_modules\dependencies
rosreestr_requirements\setup.bat также установила
в командной строке получили:
Рекомендуется использовать стандартный механизм через setup.bat для установки зависимостей, вместо их копирования.
В любом случае, у вас уже установлены зависимости.
К сожалению, возникают проблемы с установкой модуля из-за проверки зависимостей в Интернете.
В следующем обновлении мы предусмотрим возможность установки зависимостей и модулей без подключения к Интернету.
А пока исключил зависимости из пакета установки, поэтому модуль должен установиться без каких-либо проблем
Благодарю за обратную связь!
Скажите, пожалуйста, есть ли мануал или инструкция?
Это отлично!В следующем обновлении мы предусмотрим возможность установки зависимостей и модулей без подключения к Интернету.
Модуль установился корректно. Спасибо.А пока исключил зависимости из пакета установки, поэтому модуль должен установиться без каких-либо проблем
- Виктор Иванов
Здравствуйте. Не работает утилита XML-конвертер «Конвертация данных Росреестра в формат MapInfo» версия 4.1.29, компьютер зависает на стадии «импорт зон», КПТ XML образца 2023 года конвертирует прекрасно, а с КПТ 2024 года не работает. Приложил КПТ 2024 Вам на e.mail. Спасибо.
По работе «Конвертация данных Росреестра в формат MapInfo» версия 4.1.29 нужно обращаться к разработчикам .
Если данный плагин так же не работает с данным файлом , пришлите файл xml мне на почту rubtsov@complat.ru
Виктор Иванов писал(а): ↑26 июн 2024, 11:25 Здравствуйте. Не работает утилита XML-конвертер «Конвертация данных Росреестра в формат MapInfo» версия 4.1.29, компьютер зависает на стадии «импорт зон», КПТ XML образца 2023 года конвертирует прекрасно, а с КПТ 2024 года не работает. Приложил КПТ 2024 Вам на e.mail. Спасибо.
